Wolfram Mathematica NSCShadedModel
  • Apr 21, 2022 8:41 AM UTC
  • 226 views
Dear comunity.
What is the syntax to open a shaded model from Wolfram Mathematica?
analysis =  TheSystem@Analyses@NewUAnalysis["ZOSAPI.Analysis.AnalysisIDM.NSCShadedModel"]
returns
NET::methodargs: Improper arguments supplied for method named NewUAnalysis.
Thanx and BR,
Jozef
Best answer by Allie
Hi @Jozef.Pulko
For using a command with an enumerated input within Mathematica, you must first load the enum via the LoadNETType command. For example, the enum for the NSC Shaded Model is “ZOSAPI.Analysis.AnalysisIDM”, so I will enter that as shown below:
LoadNETType["ZOSAPI.Analysis.AnalysisIDM"];
Once loaded, you can choose the enumerator you wish to use by using the ` operator and the final section of the enum value. (That operator is the key to the left of the “1” and above “Tab” on a typical keyboard.) For example, to select NSC Shaded Model with the ZOSAPI.Analysis.AnalysisIDM enum loaded, we would use this command:
theSystem@Analyses@NewUAnalysis[AnalysisIDM`NSCShadedModel];
As long as the enum is loaded somewhere in the document (and evaluated), you can call any enumerator value from its list using the ` operator. This is exemplified in Sample 3 from within the C:\...\Zemax\ZOS-API Sample Code\Mathematica folder, where we insert optimization operands into the Merit Function Editor using the MeritOperandType enum.
Let me know if you have any other questions about this!
  • Apr 21, 2022 3:07 PM UTC
Hi Jozef,
The NSC Shaded model is only available if TheSystem is currently a non-sequential system.  By default, new systems are sequential mode.  Can you confirm your system is non-sequential (I don’t use Mathematica so I’m not sure if the code below has the correct @ & double quotes):
TheSystem@Mode == "ZOSAPI.SystemType.NonSequential"
If your system is already non-sequential, then it is something with the ZOSAPI enum you are calling.
  • Apr 25, 2022 3:10 PM UTC
Hi Michael,
yes my system is non-sequential. For example TheSystem@NCE@InsertNewObjectAt[2] works.
TheSystem@Mode returns
BR,
Jozef
Allie
  • Apr 25, 2022 11:20 PM UTC
Hi @Jozef.Pulko
  • Apr 26, 2022 5:43 AM UTC
This works. Thank you!
