trace vignetting surface number using ZOS-API
  • January 11, 2024
  • 77 views
redbottle
Hi All,
I know if using ZPL , RAVY() is used to trace vignetting surface number. if I need to do that using API, how to implement it? Much appreciated for the help!
  • 1129 replies
  • January 12, 2024
Hi @redbottle,
The ZOSAPI has an equivalent vignetteCode in the various raytraces. The vignetteCode is either 0 if the ray is not vignetted or the surface number at which the ray is clipped otherwise. Here is the Syntax Help for the normalized unpolarized raytrace:
You were not specific in your question, so I’m showing a basic example with the batch raytrace and a normalized unpolarized raytrace assuming you trace a single ray to the last surface of your system:
from System import Enum, Int32, Double
# Required to read the raytrace data
sysInt = Int32(1)
sysDbl = Double(1.0)
# Open batch raytrace tool
batchRayTrace = TheSystem.Tools.OpenBatchRayTrace()
# Normalized unpolarized raytrace parameters
maxRays = 1
raysType = ZOSAPI.Tools.RayTrace.RaysType.Real
toSurface = TheSystem.LDE.NumberOfSurfaces - 1
# Create a normalized unpolarized raytrace
normUnpol = batchRayTrace.CreateNormUnpol(maxRays, raysType, toSurface)
# Clear previous data (if necessary)
normUnpol.ClearData()
# Single ray parameters
waveNum = 1
Hx = 0.0
Hy = 0.0
Px = 0.0
Py = 1.0
opdMode = Enum.Parse(ZOSAPI.Tools.RayTrace.OPDMode, "None")
# Add a single ray to the raytrace
normUnpol.AddRay(waveNum, Hx, Hy, Px, Py, opdMode)
# Run the raytrace
batchRayTrace.RunAndWaitForCompletion()
# Analyze the raytrace
if normUnpol.HasResultData:
    normUnpol.StartReadingResults()
    rayData = normUnpol.ReadNextResult(sysInt, sysInt, sysInt,
                                       sysDbl, sysDbl, sysDbl,
                                       sysDbl, sysDbl)
    # Check if success and no errors
    if rayData[0] and rayData[2] == 0:
        # Print vignetting status
        if rayData[3] == 0:
            print("Ray not vignetted")
        else:
            print("Ray vignetted at surface {0}".format(rayData[3]))
# Close raytrace tool
batchRayTrace.Close()
Note that this is Python but the syntax should be quite similar in MATLAB. Have a look at the MATLAB implementation of Example 22 in the Syntax Help File if necessary.
Have a look at those articles as well:
https://support.zemax.com/hc/en-us/articles/1500005577222-ZOS-API-using-MATLAB
https://support.zemax.com/hc/en-us/articles/1500005576882-Batch-Processing-of-Ray-Trace-Data-using-ZOS-API-in-MATLAB-or-Python
I hope this helps. Any other question, let me know. Take care,
