Python _PythonStandaloneApplication object has no attribute 'TheApplication'
Yang.Yongtao
Hi Zemaxers
 I am trying the python sample code of ZOS-API (as attached below). But it does not work at the first step.
https://support.zemax.com/hc/en-us/articles/4403605141267-Generate-the-executable-in-Python-for-ZOS-API-User-Extensions
The error shows as below
AttributeError: 'PythonStandaloneApplication' object has no attribute 'TheApplication'
(after checking the zemax install root , I guess it has something with 'TheApplication'  attribute)
Environment
python 3.10
PyCharm Community Edition 2022.1
Ansys Zemax OpticStudio 2024 R1.03
pythonnet version 3.0.3
Attached code
What I have done:
checked the address below, it is correct
Could you give me some advice on this issue?
Thank you
YANG
Best answer by Yang.Yongtao
Sorry for borthering here,
the fault is the wrong path
I shall use the C:\Program Files\Ansys Zemax OpticStudio 2024 R1.03
instead of    Documents\Zemax\ZOS-API\Libraries\ZOSAPI_NetHelper.dll
Yang.Yongtao
  • 65 replies
  • July 5, 2024
seems something wrong with the Initialize method
I have tried a hard coded path, but it still does not work
Yang.Yongtao
  • 65 replies
  • July 5, 2024
chaasjes
  • Visible
  • 37 replies
  • July 5, 2024
Hi @Yang.Yongtao ,
If you are getting started with using the ZOS-API from Python, I recommend trying ZOSPy: https://zospy.readthedocs.io/en/latest/
ZOSPy makes it easier to manage the connection and solves some problems related to Python.NET 3 that you will likely run into.
Yang.Yongtao
  • 65 replies
  • July 6, 2024
chaasjes wrote:
Hi @Yang.Yongtao ,
Thank you!
I will have a try
