Performing DOE with tilt and decenter while extracting image simulation results
  • November 11, 2022
  • 137 views
  • 25 replies
Hello Everyone,
I want to run a DOE with ZEMAX where the idea is to generate synthetic data by running image simulations while changing position of lenses (adding decenter and tilt to individual lens elements in a lens stack).
I want have a bunch of tilt and decenter scenarios and would like to automate the process via API.
Is there a sample code that I could use for this application? Is there a sample code to automate image simulations and save resulting images in general that I could modify to suit my needs?
All suggestions are appreciated :)
Amit
Hi Amit
I don’t have a code that does this scenario but I think it all comes down to calling the Image Simulation in the API.
Here are two posts that will help:
Let us know if you need more help.
Hi Amit
