Not able to run example 23 from “Zemax\ZOS-API Sample Code\Python”
  • 12 October 2023
  • 108 views
Userlevel 1
i am using Zemax Optics Studio 23.1 and trying to run the python example files included in the “Zemax\ZOS-API Sample Code\Python” directory.
While others seem to work, when trying to run “PythonStandalone_23_ray_fan_native_manual_comparison.py” i get an error.
Traceback (most recent call last):
  File "c:\ex\PythonStandalone_23_ray_fan_native_manual_comparison.py", line 262, in <module>
    ray_settings.Field.UseAllFields()
AttributeError: 'IAS_' object has no attribute 'Field'
Exception ignored in: <function PythonStandaloneApplication.__del__ at 0x000001D4F7E9F880>
  File "c:\ex\PythonStandalone_23_ray_fan_native_manual_comparison.py", line 72, in __del__
TypeError: 'MethodObject' object is not callable
I run the original file without any changes.
Could somebody please possibly advise if eventually the API did evolve and this particular example file is no more compatible?
Best regards
Dimiter
icon
Best answer by David.Nguyen 12 October 2023, 18:39
Userlevel 7
Badge +2
Hi @dgeorgiev,
I believe it relates to this issue:
Basically, if you replace this line of code:
ray_settings = ray.GetSettings()
by this one:
ray_settings = ray.GetSettings().__implementation__
It should correct this error at least.
@Allie or @Chris Normanshire do you know if there’s a plan to update the eaxamples so they comply with more recent versions of Pythonnet?
Userlevel 1
Thank you David,
I greatly appreciate your quick and effective help!
Best regards
Dimiter
Userlevel 6
Badge +2
Hey @David.Nguyen - Yup we are planning to update the files! I don’t have a timeline for you yet, but it’s definitely on the radar.
