Ignoring multiple surfaces at once, ZOSAPI, python
Hello fellow optics enthusiasts,
I’m currently working on a task where I need to ignore multiple surfaces in a Zemax optical system using the ZOS-API. At the moment, I’m using the following loop:
for i in range(150, 160):
surface = TheSystem.LDE.GetSurfaceAt(i)
surface.TypeData.IgnoreSurface = True
However, this approach seems to be quite slow. Has anyone found a more efficient way to ignore multiple surfaces at once?
Any insights or suggestions would be greatly appreciated!
Thanks in advance,
Sebastián
Best answer by chaasjes
I am afraid there are no alternatives to doing this in a loop.
However, do you run this in extension mode? Updating a boolean property doesn't take much time, but in extension mode, it takes some time to update the UI. If you are using the ZOS-API in extension mode, you'll see a significant speed-up if you take one of these measures:
  • Connect to OpticStudio in standalone mode;
  • Turn UI updates off before expensive operations and on again afterwards. You can do this with TheApplication.ShowChangesInUI = False # (or True).
chaasjes
  • Visible
  • June 6, 2025
Thanks a lot @chaasjes!
Yes, I’m using extension mode. I added TheApplication.ShowChangesInUI = False before the loop and set it back to True afte and now it’s much faster!
Really appreciate your help!
Sebastián
