How to perform Standard Zernike Analysis across multiple files simultaneously using Zemax Python API and Multiprocessing
  • May 14, 2025 6:51 PM UTC
  • 319 views
Daniel Dominguez
Hi all - As the title states, I’m attempting to perform a Standard Zernike Analysis across multiple files simultaneously using the Zemax Python API and Multiprocessing (running 4 instances of Zemax). My attempt is shown below. Failures I’ve encountered include:
*** FRU__delta_init(): Attempt to start when running!
and
UnboundLocalError: local variable 'zos' referenced before assignment
I’m not sure if my approach is flawed or if I’m just attempting something that’s not allowed with Zemax or something else. Any insight you can provide would be greatly appreciated. Thanks!
Also, thank you to David Nguyen for his example code on performing a Zernike Standard Analysis here.
if __name__ == '__main__':
import multiprocessing as mp
import os
import glob
from ShortZernMonolith import ShortZernMonolith
documents_path = os.path.join(os.path.expanduser("~"), "Documents")
directory_path = documents_path + "\\SenseCheck"
# Create list of TSAV*.zmx files found in folder
TSAV_Files = []
for files in glob.glob(directory_path + '\\TSAV*.zmx'):
TSAV_Files.append(files)
# Start 4 processes of ZernCompute
with mp.Pool(4) as p:
p.map(ZernCompute, TSAV_Files)
def ZernCompute(ZemaxFile):
from PythonStandaloneApplication import PythonStandaloneApplication
import os
import pandas as pd
# Open communication with Zemax
zos = PythonStandaloneApplication()
# load local variables
TheSystem = zos.TheSystem
# Define folder to store files
QZ_path = documents_path + "\\QuickZern"
basefileName = os.path.basename(ZemaxFile)
fileName = os.path.splitext(basefileName)
# Specify fields, waves, surface and zernike terms of interest
field = [1, 3, 7, 11]
wave = [1, 2, 3]
surface = 96
zTerms = [4, 6, 7, 11]
vertex = False
sub_x = 0.0
sub_y = 0.0
sub_z = 0.0
eps = 0.0
maxTerms = max(zTerms)
# Initialize variable list to store Zernike results
zernResultsFile = []
# Load desired ZemaxFile
TheSystem.LoadFile(ZemaxFile, False)
# Open a Zernike Standard Analysis
ZernikeStd = TheSystem.Analyses.New_ZernikeStandardCoefficients()
# Change settings and compute Zernike Standard Analysis
for j in range(len(wave)):
for k in range(len(field)):
Settings = ZernikeStd.GetSettings() # Get analysis settings
# Apply Settings
Settings.Field.SetFieldNumber(field[k])
Settings.Surface.SetSurfaceNumber(surface)
Settings.Wavelength.SetWavelengthNumber(wave[j])
# Settings.SampleSize = Samp
Settings.ReferenceOBDToVertex = vertex
Settings.Sx = sub_x
Settings.Sy = sub_y
Settings.Sz = sub_z
Settings.Epsilon = eps
Settings.MaximumNumberOfTerms = maxTerms
# Run analysis
ZernikeStd.ApplyAndWaitForCompletion()
# Send Zernike results to text file
tempFile = QZ_path + f'\\ZernTempFile{fileName[0]}-{j}{k}.txt'
ZernikeStd.GetResults().GetTextFile(tempFile)
# Open and read the text file
with open(tempFile, 'r', encoding='utf-16') as F:
Lines = F.readlines()
ZernResults = []
for Index in range(38, len(Lines)):
SplitLine = Lines[Index].split()
zCheck = str(SplitLine[0])
TermCheck = int(SplitLine[1])
Value = float(SplitLine[2])
# Filter for desired Zernike Terms
for i in range(len(zTerms)):
if zCheck == 'Z' and TermCheck == zTerms[i]:
ZernResults.append(Value)
#os.remove(tempFile)
zernResultsFile.extend(ZernResults)
ZernikeStd.Close() # Close the analysis
print(f"Analysis of {ZemaxFile} complete.")
df = pd.DataFrame(zernResultsFile).T #Change list to dataframe
# Write data from zernResultsFile to CSV
ZernResultsCSV = os.path.join(os.sep, QZ_path, f'{fileName[0]}-ZernResults.csv')
df.to_csv(ZernResultsCSV, mode='a', index=False, header=False)
del zos
chaasjes
  • Visible
  • Jun 2, 2025 1:33 PM UTC
Good to see you create separate OpticStudio instances in the separate processes, as the ZOS-API does not allow to connect to multiple OpticStudio instances from the same process. This is a common pitfall when trying to parallelize code utilizing the ZOS-API.
However, there are multiple things that may cause issues here:
  • A new OpticStudio instance is opened for every call to ZernikeCompute, which may reduce or eliminate the advantage of using multiprocessing;
  • You attempt to delete zos at the end of ZernikeCompute, but the zos object is still referenced in TheSystem. This will cause the zos reference  to be deleted, but the object itself will not be deleted until TheSystem can be cleaned up. Luckily, this is likely to happen when the function returns. Still, the UnboundLocalError may be related to this, but that's hard to find out if you do not supply stack traces.
It would be more efficient to create stateful processes that create a new OpticStudio instance when initialized, and then use the same OpticStudio for all calculations in that process. This is not possible with Python's multiprocessing library, but I've successfully done this with Ray actors.
Finally, I recommend taking a look at ZOSPy, an open-source Python library for communication with OpticStudio. ZOSPy includes ready-to-use parsers for a number of OpticStudio analyses, and supports the Zernike Standard Coefficients analysis.
