Change solve type on thickness using Matlab
  • May 12, 2020 1:09 AM UTC
  • 278 views
Jonathan.Bumstead
I'd like to run two different optimizations with different merit functions through Matlab. Before running the second optimization, I need to change the Solve Type of some thicknesses and radii to variables. The following code provides the current solve type, but it is a read-only property. Is there some way to change the solve type using Matlab?
TheLDE = TheSystem.LDE;
S1_CollSolve = TheLDE.GetSurfaceAt(52);
S1_CollSolve.ThicknessCell.Solve
Thanks for your help.
Jon
Hello Jon,
Thanks for your question!
In order to change the solve type, first you have to create a new solve type by the CreateSoveType member function of the ZOSAPI.Editors.IEditorCell interface using the SolveType enumeration of the ZOSAPI.Editors namespace, please see it below:
Then, you can set the new solve type by the SetSolveData member function ZOSAPI.Editors.IEditorCell interface.
Please find two examples below, the first one shows how to set an F# solve, while the second shows how to set thermal and config pickup solves:
You may find further examples in Examples 15 and 18.
I hope this helps!
If you have further questions please ask and we will be happy to help!
Csilla Timar-Fulep
Hello Jon,
I hope this helps!
Jonathan.Bumstead
This was very helpful. Thanks for your reply.
