The other day python.Net version 3.0.0, supporting Python 3.10, was released. Hence, I’m curious to hear when we can expect ZOS-API to support this very much appreciated combo.
Hans
Hans
Hi Hans,
I kinda want to know as well now.
I’ve read about the match case statement in Python 3.10. What else are you interested in this combo?
Hi David,
Yes, match-case statement is very interesting.
But as someone who’s switching from 30 years with Matlab to Python, better error syntax and typing syntax is much appreciated. After all, 3.8 was released 3 years ago :)
/Hans
Hi Hans,
It makes sense.
Kudos to you for switching programming langage after 30 years. It speaks about your open-mindeness.
Good luck on your Python journey,
Hi David and Hans
I checked with our developers. The ZOS-API is a .NET 4.8-based library.
So if Python.net 3.0 supports .NET 4.8, then it should work without any issues. And Python.NET is compatible and tested with Python releases 3.7 - 3.10.
But we haven’t done any specific tests.
Hi Sandrine,
Thanks Sandrine and David,
Seems like it’s best to wait a bit and let things converge first.
Cheers, Hans
Hi David! Thank you for pointing this. I had missed it.
All I can see that it says Python.NET gives “a nearly seamless integration with the .NET 4.0+ Common Language Runtime (CLR)”.
I’d like to add that
Hi
Thank you all on this forum thread for starting this conversation.
One more thread with an issue using Pythonnet 3.0:
