Pythonnet 3.0 not recommended to use for ZOSAPI-Python
  • October 17, 2022
  • 296 views
Pythonnet is a package that gives Python programmers an integration with the .NET Common Language Runtime (CLR).
Our ZOS-API is a .NET 4.8-based library. So the Pythonnet version should support .NET 4.8 to be used with ZOS-API.
We had some reports that pythonnet 3.0 didn’t work with ZOS-API. I also did a couple of tests last week and encountered issues. So the recommendation for now is not to use pythonnet 3.0 with ZOS-API.
I personally use pythonnet 2.5.2.
Be the first to reply!
