Close ToleranceDataViewer window pop out after tolerancing analysis finished
I am running tolerancing analysis (TA) using Matlab. I noticed that one tolerance data viewer window will show up after the TA is finished. I would like to close the viewer window using Matlab script however I was not able to find the right way to do it in ZOS-API manual. Do you know how to close the viewer window using Matlab script? Thank you very much.
Hi Yao,
This is an interesting question. I think the Tolerance Data Viewer is a Tool and the one that’s create by the Tolerance tool can’t be access easily through the ZOS-API (at least I did not manage). If it was an analysis you could have found it afterwards with the Get_AnalysisAtIndex().
However, if you don’t want it at all. There’s a property of the Tolerance tool that is called OpenDataViewer. If you set it to False, it shouldn’t open this window. This is the line I would use in Python:
TheTolerance.OpenDataViewer = False
I hope this helps. Take care,
  • 1149 replies
  • March 4, 2022
Hi Yao,
  • March 6, 2022
Thank you very much, David. That is exactly the answer I am looking for.
