Change wavelength in Geometric Image Analysis
adam2877
Hi All,
I’m trying to automate some Geometric Image Analysis tasks but am struggling to change the wavelength in geometric image analysis.
python 3.10.9
Optics Studio 23.1
I’ve set up the image analysis I want in the project (Cross X, Field size, image size, pixels etc). I’m trying now to loop over wavelengths and save the results. My problem is I can’t figure out how to change the wavelength number within ZOS-API. As far as I can tell the IMA keywords don’t have Wavelength. Thanks for any help!
from the help of ModifySettings keywords
IMA_FIELD: The field size.
IMA_IMAGESIZE: The image size.
IMA_IMANAME: The image file name.
IMA_KRAYS: The number of rays x 1000.
IMA_NA: The numerical aperture.
IMA_OUTNAME: The output file name.
IMA_SURFACE: The surface number.
IMA_PIXELS: The number of pixels.
example code:
geo = TheSystem.Analyses.New_GeometricImageAnalysis()
geo_set = geo.GetSettings()
cfgfile = os.path.join(pth,'geo_an_sett.cfg')
geo_set.SaveTo(cfgfile)
geo_set.ModifySettings(cfgfile,'IMA_Wavelength'?,'1')  # I can’t find an appropriate keyword to give here
geo_set.LoadFrom(cfgfile)
geo.ApplyAndWaitForCompletion()
res = geo.GetResults()
res.GetTextFile(os.path.join(pth,'textfile.txt'))
r1 = np.loadtxt('analysis/textfile.txt',skiprows=18)[:,1]
nb.
geo_set.Wavelength gives an attribute error.
In [33]: geo_set.Wavelength.SetWavelengthNumber(1)
Traceback (most recent call last):
  Cell In[33], line 1
AttributeError: 'IAS_' object has no attribute 'Wavelength'
Yes, the piece of code I gave you run on my machine (Python 3.8.13, Pythonnet 2.5.2).
What version of Pythonnet are you using? It should be 2.5.2 or older. If you find that you are running Pythonnet 3.0, please try 2.5.2. There have been issues with analyses and pythonnet > 2.5.2. Also, I don’t know if Pythonnet 2.5.2 is compatible with Python 3.10.9, you should check that out. Have a look at that perhaps:
Dear Adam,
Whenever you try a new analysis in the ZOS-API, I strongly suggest evaluating the property HasAnalysisSpecificSettings. If True, this property tells you that the settings have been fully implemented in the ZOS-API and you don’t need to use the ModifySettings method.
In the case of Geometric Image Analysis, you can type:
print(geo.HasAnalysisSpecificSettings)
And it should print True.
It is a bit tricky to find in the Syntax Help (you need to click on IAS_ in the analysis interface next to GetSettings() and then find the square box which points to the Geometric Image Analysis), but these are the specific settings of Geometric Image Analysis:
 The way you use these settings are as follow:
# Geometric Image Analysis Settings
geo_settings = geo.GetSettings()
# Wavelength
geo_settings.Wavelength.SetWavelengthNumber(1)
# Field
geo_settings.Field.SetFieldNumber(1)
# Field size
geo_settings.FieldSize = 1.0
# Apply settings and run analysis
I hope this helps. Take care,
adam2877
  • March 21, 2023
Hi David,
Thanks a lot for your reply. I saw that it has the specific settings flag True but couldn’t find the methods in the documentation---until now!
Does your code run for you?
geo_settings does not show the official methods. I tried running your code and get an AttributeError
# Wavelength
  Cell In[15], line 1
The documentation says it’s implemented, but the behavior I’m seeing is as if it isn’t…
Thanks for any insight
  • 1129 replies
  • March 21, 2023
adam2877
  • March 21, 2023
Brilliant! pythonnet version solved it.
Thanks for your help!
