As mention in the group description, this User Group is for OB users and prospects to connect, share experiences and provided assistance. Here is the in-depth group overview:
What is OB?
Zemax OpticsBuilder enables CAD users to simulate the difference in performance based on light propagation through optics alone compared to light propagation through optics and mechanics together. By analyzing how light interacts with the mechanical assembly surfaces, CAD users can detect optical errors early, reduce back-and-forth communication with Optical Engineers and avoid expensive prototyping.
Zemax OpticsBuilder is currently available for Creo Parametric 4,5,6 and 7
Links and Help
If you are new to OB, we highly recommend to go through the Getting Started series of our Knowledge Base:
Getting Started with Zemax OpticsBuilder
Forum post Roadmap
OpticsBuilder Feature Stories 22 series
  • OB22: Feature Stories - Introduction: Published
  • OB22: Ray Geometry - Ultra Short Throw Projector: Published
  • OB22: Ray Footprint Boundaries  - Riflescope: Coming soon
Support
Active licenses users are also entitled to open up a direct and individual support case with an Optical/Optomechanical Engineer here at Zemax. You can do so by directly emailing support@zemax.com (Please use the same email address which you have used to created your Zemax login) or use your Zemax Profile:
However, please consider that every question which gets asked here in the forum might be helpful to other users as well
