Non-Sequantial Mode Laser Source
  • June 6, 2024
  • 344 views
birhan_uguz
Hello, How can I create the attached sample laser in non-sequential mode considering we are working outside the Rayleigh range? Should I choose Source Gaussian, Source Point or Source Ellipse and how can I give the 35mrad angular distribution with the correct apodazition factor? Fiber core diameter 245um.Thank you so much
Lenror Li
  • Visible
  • 34 replies
  • June 18, 2024
If you want to simulate the emission of laser through a fiber, I recommend that you refer to the linked article.
Multimode fiber bundle | Zemax Community
