Hello guys,
I am designing a wide-angle diffuser using micro-lens array (Light source: VCSEL array).
The problem is the resulting shape in the polar diffuser.
In my knowledge, the distortion of the MLA Diffuser should appear as a barrel.
However, the result is pincushion distortion.
When setting up the polar detector, is it possible to change the photometry ies type or other conditions?
Sicerely
