I’m trying to make a relation between zernike polynomials that describe spherical aberrations and laser beam diameter, glass thickness and focal length of the lens. I read from as source that the eight zernike term for a mirror can be given as C8=D^4/[3072* wavelength*(focal length^3)] where D is mirror diameter. Is there a similar formula for a lens? if no,how do you advise i go about it on zemax?
