April 2023 Community Newsletter
Allie
  • 343 replies
Welcome
Welcome to the April edition of the Ansys Zemax Community newsletter!
Cherry blossoms in full bloom in Tokyo.
Picture taken by @Takashi Matsumoto
This newsletter provides updates for you, the user, on technical content you might find interesting or helpful. This newsletter features content that has been posted or was popular during the last month! Check out what we have for you below:
Is this newsletter missing something you think others should know about? Or is there something you learned here that you didn’t know before? Let us know in the comments below!
Zemax-er Spotlight: Luca Cellerino
This month, we are featuring Luca Cellerino (@Luca.cellerino). Luca is a very active user of our community and has been discussing topics around color and luminance performance on the forum.
To learn more about Luca’s background and experience in the industry, click Show content below.
Show content
→ Tell us about yourself and your company
I have been working in the R&D department of an electromechanical company for about 25 years. The company is part of the Bitron group and is engaged in various sectors in addition to the automotive sector such as household appliances, air treatment, energy distribution, etc. I deal with the validation of systems called "visible switches" with respect to customer requirements. The simulations are mainly about color and luminance performance.
→ What in the industry are you excited about?
I love the daily challenges and innovation of this sector.
If you could offer one piece of advice to someone using OpticStudio, what would it be?
I would have liked to learn more about the optimization algorithm, I later discovered its potential.
→ What's the most challenging problem you've addressed with the help of OpticStudio?
In general, the light guides are the most challenging part and OS solves them in an excellent way.
→ What topics are you looking forward to discussing with your fellow Community members?
One of the problems I face every day is the rendering of environments, the need to represent the application environment of the optical system in a real way is gaining ground, for example vehicle ambient lights or surface-shaped color detectors. How did colleagues solve?
→ What do you enjoy most about the Zemax Community/forums?
I like the community's applied experience and quick responses.
The Community in Review
Featured Community Posts
Did you know that some of our most active forum users are former Zemax employees? We are so happy to see them continuing to share their knowledge on our Community. This month,@David.Nguyen (former ACE team member) and@MichaelH (former R&D/Product team member) used their expertise to create the posts below. Check it out!
  • User @MichaelH is showing how tweak the sample files to use the modern version of PythonNET as the latest versions of PythonNET contains some change to the way inheritance works.  PythonNET is now more in line with C# where you have to use the proper static variable type.
Ask An Engineer: Tolerance analysis on Binary 2 diffractive surfaces
Every month, the Ansys ACE team looks for forum posts that can be answered in a quick video. In general, we are searching for lingering un-answered questions, but may also respond to questions we deem as good “FAQs”. If you have a question you think we should take a look at, let us know in the comments below.
This month, Senior Application Engineer Yuan Chen responded to the following thread:
Code Exchange Latest Editions
  • @Michael Chenghas has written a user extension that acts like a “wizard”. It is meant to help users set DLL parameters for example when working with grating data for Lumerical DLL. The tool is mainly useful when we need to set up multiple objects and parameters.
Chinese Forum: Popular Topics
Ansys ACE member @yuan.chen created a forum post which shows how to calculate the FWHM of Huygens PSF. Take a look here:
分享一个计算惠更斯PSF半峰全宽(FWHM)的宏 | Zemax Community
The forum post about the Lumerical-Zemax dynamic link is updated as well.
Lumerical RCWA和Zemax OpticStudio的动态链接 | Zemax Community
Japanese Forum: Popular Topics
Ansys ACE member @Ryosuke.Niitsu  shared how to use the OpticStuido to optimize the "white". For lighting applications, different combinations of RGB can produce various color temperatures of white, and OpticStudio can simply calculate how to combine RGB to calculate the desired color temperature of the design.
光源のパワーの最適化をして白色を設計するシミュレーション
Knowledgebase Updates
Our APAC team is constantly working on translating Knowledgebase content into our supported languages. The Japanese and Chinese language Knowledgebase has recently been updated with the following:
  • 立方体卫星设计-第一部分:使用 Ansys Zemax 软件建立立方体卫星系统 by@Jordan.Teich and translated by@Haosheng Hu
    在航空航天工业领域中,立方体卫星(CubeSats)已然是一种低成本、易制造的航天光学系统的解决方案。通过制造一组更小、更实惠的系统,使得为航天产品开发生产线方法成为可能。
    立方体卫星光学系统的制造商们需要一个准确并可靠的方法来开发光学设计和对系统进行光机械封装,以及对系统在轨时的结构和热影响进行建模分析。 本系列文章将利用Ansys Zemax和Ansys其它软件,对立方体卫星系统进行高阶开发。我们将介绍一个集成的软件工具包是如何精简设计和分析工作流程的。
  • OpticStudio 中的复合表面 by@Chenfeng.Gu
    本文主要介绍了 OpticStudio 中的复合表面类型,该功能将作为 Zemax OpticStudio 22.3 版本(支持于订阅制专业/旗舰版)和 Ansys Zemax OpticStudio(专业/旗舰/企业版)2022 R2.02版本中一项新颖、有趣且实用的功能。该功能将延展支持出 OpticStudio 中许多新功能和可能性。
  • LumericalとOpticStudio間でシミュレーションを変換する方法 by@Sahil and translated by@Kensuke.Hiraka and@Takashi Matsumoto
    このチュートリアルでは、OpticStudioの情報を、Lumericalの有限差分固有モード(FDE)ソルバー用に変換する方法を紹介します。こうした変換は、バルク光学系と導波路の両部分から構成される、多段式の光学系を扱う場合に威力を発揮します。今回の例では、合焦レンズから小型の石英ファイバへの結合を検討します。まず、偏光ビームをZemaxビームファイル(.zbf)としてLumerical固有モードソルバーにエクスポートします。次に、このビームとLumerical固有モードソルバーで生成したモード間のオーバーラップやパワー結合率を計算します。ビーム間のオーバーラップ解析により、Lumericalモード解析で得られるモードの中から、より適切なモードがわかります。このモードを、ZemaxビームファイルとしてエクスポートしてOpticStudioに戻します。
Ansys Optics Application Gallery
In this new section of the Community Newsletter, we will be featuring the work of the Ansys Optics ACE team. The team is constantly creating new and exciting tutorials and workflows which are then published to the Ansys Optics Application Gallery. The Gallery features content from all of our optical tools and beyond with the express goal of showing users how to use our simulation tools for any application.
This month we are spotlighting:
Metalens – Ansys Optics
  • The goal of this example is to design a diffractive metalens consisting of cylindrical nanorods. The radius and the arrangement of the nanorods are tailored to create a desired phase profile on the metalens surface. The design is verified in Ansys FDTD, RCWA (Rigorous Coupled-Wave Analysis) and OpticStudio through near- and far-field analyses.
Be the first to reply!
