When you want an object to have scattering properties, you’ll want to open the object properties and go to the scattering tab. You can open the object properties right above where you see the column title “Object Type” in your editor.
Note that in order to see scattering effects, you have to have “use polarization” and “scatter rays” checked in both your layout settings and in your raytrace settings.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
