Service Pack
OpticStudio 20.2.1 Release Notes
Allie
  • 338 replies
Released: June 23rd, 2020
OpticStudio 20.2.1 contains the following fixes and enhancements.
Performance & Stability
  • ZOS-API – Added error code of SolveStatus.Failed to the API for situations where the solve cannot be properly set.
  • Tolerance Data Viewer – Improved default widths for columns in the Tolerance Data Viewer.
  • Image Simulation – Updated Image Simulation so the “Output File” setting matches the same orientation as the result displayed in the GUI.
Bug Fixes
  • Black Box Files – Fixed paraxial magnification calculation with Black Box files in specific situations with a dummy surface immediately before.
  • GRIN Ray Tracing – Fixed speed and convergence for GRIN ray tracing at steep angles of incidence for all sequential GRIN surfaces except Gradient 5 and Gradient 9.
  • Radiant Source Models – Fixed an issue with not being able to View Radiant Source Model or Generate Rays introduced in 20.2.
  • RMS Field Map – Fixed issue in RMS Field Map and RMS vs Focus where the analysis would run with the incorrect wavelength.
  • Tolerance Script – Fixed an indexing mismatch with the tolerance script CPAR keyword where the parameter column was shifted by a value of 12.
