The surface deformations I’m reading into the system cause the shape of the pupil in the wavefront map analysis to be significantly distorted. However the REAX and REAY merit function operands are unaffected. Similarly if I look a the footprint plot it does not appear to be distorted at all.
Do the Merit Function REAX and REAY commands not consider the effect of surface deformations from STAR?
If not - what would be a good way to achieve something similar?
