[Webinar] Modeling a Flash Lidar System Using Optical-Optomechanical Zemax Workflow [Q&A]
  • October 3, 2022
  • 142 views
mojtaba.falahati
This thread is dedicated to the upcoming webinar: Modeling a Flash Lidar System Using Optical-Optomechanical Zemax Workflow. Any questions received during the webinar will be responded to as a reply on this thread. Feel free to post your own questions! The speaker will be notified and will respond as long as the thread is still open.
Be sure to subscribe to this thread if you want to see additional discussion regarding this webinar topic. The thread will be open to new replies for a limited time following the event.
[The event has concluded]
Webinar details
Date: Thursday, October 13th
Time: 6:00 - 6:45 AM PDT | 11:00 - 11:45 AM PDT
Presenter: Mojtaba Falahati, Senior Application Engineer
Abstract:
In the consumer electronics space, engineers leverage lidar for several functions, such as facial recognition and 3D mapping. Obtaining three-dimensional spatial data for use in a small-form package has caused this solid-state solution to become more commonplace in consumer electronics products, such as smart phones and tablets. In this webinar, we explore the optomechanical design of a flash lidar system using an Ansys Zemax workflow to turn an optical design into reality. We will take a lidar system created in OpticStudio and implement mechanical packaging on the optical design using OpticsBuilder. This workflow enables improved communication between optical and mechanical designers as they navigate design changes and assess impact on optical performance while introducing optomechanics. It also allows designers to detect costly errors early in the design process and export the full optomechanical design back to OpticStudio seamlessly.
Pinned reply
October 17, 2022
Watch the recording!
A recording of the presentation may be found here: Modeling a Flash Lidar System Using Optical-Optomechanical Zemax Workflow
Allie
  • 346 replies
  • October 17, 2022
