Reset 3D layout
  • Aug 8, 2022 8:09 AM UTC
  • 232 views
P.Johnson
Hi All,
When using the 3D layout I often end up rotating the model and changing the zoom. I know that there is a button in the ribbon to reset the zoom, but there doesn’t seem to be one to reset the rotation. So far my work around is to go into the 3d Layout settings and manually reset the rotation of each axis. I just wanted to make sure I hadn’t missed a tick for resetting the rotation such as a hot key or a hidden button somewhere.
Pete
Best answer by Ray
Hi Pete
There are 4 orientations that you can access in the toolbar through a drop down (looking like a house with three lines)
  • Aug 8, 2022 11:01 AM UTC
Hi Pete
