ZPL solve error
  • February 13, 2024
  • 125 views
Sean Turner
I am getting this error when I open a file, but I don’t understand why. The multi-configuration editor has a pickup solve on Configuration 3, Operand 7, so why is it saying ZPL solve?
The error appears multiple times, each time for a different MCE operand that should have a pickup solve. I just went through and re-created all the pickup solves, saved the file, then opened again only to see the same error messages and all my pickups removed. What is happening?!
Sean Turner
  • February 14, 2024
Adding some more context. I am using Zemax OpticStudio 23.2.1
The MCE is set up with operand LTTL in row 1. The strings in each column include some text indicating the name of the system, and a wavelength. There are MOFF operands later on with pickups set to get the value from operand 1, LTTL. This provides a reminder for which wavelength is associated with which config as we are scrolling down in the MCE.
Here is an example I made in a blank lens file. This is what it looks like after pickups are added.
I then save as .ZMX and reopen. Now I get the error message and the MCE looks like this. For some reason, only config 3 gives the error, but pickup solves have been removed from configs 2, 3, 4. The string value remains in config 2 and 4 though...
As a test, I added the pickups back and saved again, this time as .ZOS. When I open the ZOS file, there is no error and the MCE has not been changed.
So I believe this is a bug. I can work around it, but it would be nice to know what’s causing it.
