ZPL/ INPUT numeric value to string
  • May 17, 2022 12:20 PM UTC
  • 1029 views
How does one convert the numeric value obtained from user INPUT to STRING data type?
Thanks
Best answer by MichaelH
Hi Asuku,
To convert a value to a string, you should use $STR(val).  This will use the currently defined FORMAT keyword, so if you want to convert to an integer, double, or scientific notation, you will need to use the FORMAT before $STR(val).
Likewise, if you want to convert a string to a numeric value, you can use either SVAL(str$) or LVAL(str$) (SVAL will use a period as a decimal separator while LVAL will use the locally defined character as the decimal separator).
  • May 17, 2022 5:18 PM UTC
Hi Asuku,
