ZPL in sequential mode
  • July 24, 2024
  • 113 views
Masato.Aketagawa
Hello everyone. This is my first time asking a question, so please understand that there may be some inadequacies.
We succeeded in giving random Zernike coefficients to Zernike surfaces with non-sequential modes. However, we could not do the same with Zernike standard phases in sequential mode using the same ZPL.
Are there any different conditions when dealing with ZPL in sequential and non-sequential modes?
@Masato.Aketagawa
Welcome to the community. Yes there are differences in ZPL between sequential and non-sequential.
You did not copy your code, so I can’t say what is wrong exactly. I am guessing you are using SETNCSPARAMETER to give the Zernike coefficients to the Zernike Surface object. If your Zernike Surface object is on line 1 of the Non-Sequential Component Editor, your code might look like so:
object_number = 1
parameter_number = 7
coeff_r2 = 1.2345
SETNSCPARAMETER 1, object_number, parameter_number, coeff_r2
In sequential mode, assuming your Zernike Standard Phase is Surface 1:
surface_number = 1
parameter_number = 15
zernike_1 = 1.2345
SURP surface_number, PARM, zernike_1, parameter_number
In general, you will have to adjust your ZPL macros for sequential from non-sequential and vice versa.
  • 1149 replies
  • July 24, 2024
@Masato.Aketagawa
object_number = 1
coeff_r2 = 1.2345
surface_number = 1
zernike_1 = 1.2345
