ZOSAPI -MATLAB Field Normalization Type
  • April 10, 2020
  • 77 views
I'm trying to change the field normalization type from Radial to Rectangular in MATLAB but cannot figure out the Syntax:
I've tried the following
sysField = TheSystem.SystemData.Fields;
1. sysField.Normalization(ZOSAPI.FieldNormalizationType.Rectangular);  - This doesn't work because Normalization is property with a get/set
2. sysField.Normalization = ZOSAPI.FieldNormalizationType.Rectangular;
3. sysField.Nomalization.GetType = ZOSAPI.FieldNormalizationType.Rectangular;
and
4. ZOSAPI.FieldNormalizationType.Rectangular;
Will somebody point me in the correct direction to figure out this syntax?
Ali H
  • Visible
  • April 21, 2020
Here we are using the Normalization set property of the IField Interface to return the FieldNormalizationType:
but as the Field Normalization Type is an enumeration, we need to use
ZOSAPI.SystemData.FieldNormalizationType.Rectangular,
so we need to write:
sysField.Normalization = ZOSAPI.SystemData.FieldNormalizationType.Rectangular
I hope this helps!
