Zemax
  • Aug 30, 2024 6:23 PM UTC
  • 200 views
Hi Everyone,
I need some clarification on an issue I'm encountering.
I’ve designed an optical system to visualize the posterior of the eye. Here's a clear outline of the problem:
  1. I started with an existing camera intended for retinal imaging and designed a lens system (Lens 1 to Lens 14: Camera Lens) using the specifications from the datasheet. I also added a set of lenses (Lens 15 to Lens 23: FOV Reducer) to decrease the camera lens's field of view (FOV), which originally has a 120-degree FOV.
  1. Now, I want to integrate this camera with my existing assembly, including the last three lenses (Lens 24 to Lens 32). I’ve simulated the combined setup, including the camera lens with sensor considerations, the FOV reducer, the existing lenses, and the eye. The simulation shows that the focus is on the retina.
  1. However, when I set up this system on the benchtop, I consistently see the iris in focus but not the retina.
I would appreciate any insights or comments on why I might be unable to focus on the retina as intended. For reference, I am attaching a compressed folder with the design details.
Thank you for your attention, will be waiting everyone insight on the problem.
Ashok
@Sharadindu.Banerjee
Next time, you may want to write a more specific title to your question. Stack Overflow has an article about asking good questions for your reference:
https://stackoverflow.com/help/how-to-ask
Also, you might have forgotten to attach your compressed folder. Could you double-check and upload it again if necessary?
Hi David,
Thank you for the suggestion. I understand that the title isn’t ideal, but I was unable to create a new one on the forum; it only allowed me to use the pre-existing titles. I chose the best-fitting option from the list. But from the next time I’ll keep it in mind.
I’ve now attached the compressed folder. I hope it is visible and accessible to everyone.
Ashok
This is a duplicate of
