Why the hammer doesn't change the lens
  • March 23, 2021
  • 236 views
I am trying to use hammer optimzation with material substitution, I am using multiconfiguration, why my lens doesn't change with the hammer
optimization? Is there something prevent from changing? Thanks a lot.
Berta.Bernad
  • March 24, 2021
Hi Weihua,
It can be that there are no glasses that match the criteria defined in your glass substitution template so it is not possible for substitution to proceed. Or that a change in the materials don't give a lower merit function. If your glass is controled in the Multi-Configuration Editor, OS won't allow you to use the Substitute Solve in the Lens Data Editor.
Sometimes I have the same issue, I am not clear about the solution yet. However, I suppose the merit function editor setup might make the difference. Last but not least,  the layout should back itself out of a poor starting point, if any.
  • November 4, 2021
Hi Jason,
I think it would help a lot if you could share a file which demonstrates the issue you are describing.
