Why does phase of reflected electric field shifted by a pi compared to my calculation
  • Nov 6, 2019 3:18 AM UTC
  • 274 views
Michael Cheng
For example, you can open the following built-in sample.
\Documents\Zemax\Samples\Sequential\Tilted systems & prisms\Prism using total internal reflection.zmx
If you check the "Phase vs. Angle", you can see the phase delay introduced to S and P polarization.
And if you check in Wiki page, you can find the phase delay for P polarization has a shift of pi compared to the result in OpticStudio.
https://en.wikipedia.org/wiki/Total_internal_reflection#Phase_shifts
Why is shift happen?
Michael Cheng
  • Nov 6, 2019 3:38 AM UTC
This is mainly about convention. There are two choices for phase shift for the reflected ray, either Abelès (thin film) or Nebraska Muller (ellipsometry).
A good explanations can found in the following documents:
https://spie.org/news/phase-matters?SSO=1
The following is an abstract.
In OpticStudio, we use the thin film convention. Therefore, when calculating the phase retardance, the following equation should be used.
