Why Can I Not Place a Thermal Pickup on the Conic Constant?
  • Jun 16, 2020 6:58 AM UTC
  • 142 views
Sean.Lin
On the multi-configuration editor, there is a special solve called a thermal pickup. This pickup solve is used to compute a new value for a multi-configuration parameter based up on the temperature and pressure of the new configuration as compared to the 'reference' configuration. Thermal pickup solves only affect data for certain types of multi-configuration values.
The thermal expansion and contraction is assumed to be isotropic, thus the linear dimensions change equally in all directions. Therefore, a solid glass sphere is still a sphere after being heated or cooled. In the same manner, a parabolic surface , with conic of -1, will still be parabolic after any temperature change and thus the conic constant is temperature invariant. This makes sense since the conic constant is a unit-less quantity.
