Which tools to use when working on a Head-up-Display? Tutorials & Applications shared .zar file is not opening
  • July 16, 2022
  • 183 views
Hello everyone,
For somewhile I am trying to pursue the https://support.zemax.com/hc/en-us/articles/1500005577782-Which-tools-to-use-when-working-on-a-Head-up-Display-
Tutorials & Applications in knowledgebase,
Throughout the tutorial, at specific points there are directions to open the related .zar documents.
Upto step 3, every zar files were opened but when I tried to open the
HUD_Step3_NONSEQ_after_tidying_up.zar” file, it gives a message as shown below;
Anybody to make comment on this, before this point of .zar documents every zar docs were properly opened, where might be the error on opening this zar.?
Thanks in advance,
Onder.
Best answer by Berta.Bernad
Hi Onder,
I was able to open this file, so it doesn’t seem to be anything related with this particular archive.  Would you please try to launch OpticStudio by right click > Run As Administrator?
Also, make sure that you have Admin privileges to write on OneDrive\Documents\Zemax|SAMPLES
Berta.Bernad
  • July 18, 2022
Hi Onder,
