what is the operand for the chief ray angular coordinates for x and y
  • Nov 27, 2023 8:19 PM UTC
  • 974 views
hi,
I would like to know how to report the angular coordinates of the chief ray relative to the vertex of a surface.
specifically, i would like to report (or know the operand) of the angular X and Y coordinates ( the X and Y in the upper left of the image below).
Hi @John.Domm,
You could use RETX, and RETY, which are the real ray x-, and y-direction tangents, respectively. Then, you can apply an ATAN with Flag = 1 for degree.
In this dummy example below, I’ve a single field at X = 2.5 deg, and Y = 5.0 deg, and I’ve changed the OBJECT thickness to 200 so a spot is actually visible in the Spot Diagram. Note that I’m using a Rectangular Field Normalization.
Let me know if this helps.
  • Nov 28, 2023 12:46 PM UTC
Hi @John.Domm,
  • Nov 28, 2023 3:47 PM UTC
Hi David
yes this works!  thank you so much!
John
Erkang Wang
If I include more fields in the simulation, which field's chief ray angle am I calculating? Thanks!
