What is the best practice to design a double-pass system?
  • September 14, 2022
  • 578 views
In case of microscopy, you have one design for projection i.e., illumination through the objective onto the actual IMG plane. The 2nd design treats this IMG plane as OBJ plane. Common elements between both designs being a beam splitter for instance. Is it possible to have these two designs forward and backward in one single zemax design?
Also, if the system has coordinate breaks/tilts/folds - is having double-pass design advisable or is it better to have two separate design files?
 Thanks - AS
Best answer by Mark.Nicholson
Hi Asuka,
You can definitely do it either way, as Sandrine says. My personal preference is to do it as a single sequential file. Build the file out as far as the reflecting surface, and then use the Make Double Pass tool to create the reflection. Edit out any second-pass surfaces you don’t need and then carry on.
Once you have built out the whole system, if you wish you could use the Make Conjugate tool in the Multi-Configuration editor
to create configurations which represent the various sub-systems of your whole system. Remember also the merit function operand IMSF that lets you redefine the image surface on the fly, so if you wanted to optimize for image quality at the intermediate image and final image simultaneously, you could have a merit function like
IMSF {intermediate image surface}
RMS Wavefront (or whatever)
IMSF {final surface}
RMS Wavefront or whatever
If you do decide to go down the separate systems path, remember that not only is the IMA of the first system the OBJ of the second, but the exit pupil of the first system is the entrance pupil of the second system. It is also harder to optimize the common optics as they appear in two separate files with no relation to each other. That’s why I prefer to do it as a single file.
  • Mark
Hi Asuku!
In that article, they modelled each part separately and then did a non-sequential model.
You could create the two systems in a multi-configuration file but it will take a bit of time to set up.
Hi Asuka,
  • Mark
