What does the "thickness aperture" mean in the Annual Aspheric Lens
  • October 20, 2022
  • 299 views
In the creation of “annual aspheric lens”, it mentions that : The aspheric rear face is offset from the front by a thickness measured at a specified radial aperture, which may be zero.  The offset means the thickness.  in the parameter setting, there is a parameter named “ Thickness aperture”.   I am puzzled at the setting of this  thickness.
Is it a thickness along  z axis?   how to calculate the thickness?   what does the “ Thickness aperture” mean here?  How can I relate this “thickness aperture” to the specific geometric figure?  Some times, when changes the value of  “thickness aperture” , the geometric figure does not change at all.  could someone describe this?  Thank you very much.
Best answer by Ethan
Hi @ruik.Zhang,
The meaning of “thickness aperture” tells OpticStudio at what radial distance you want to define the object thickness. This is best explained with a picture of the cross-section of an Annular Aspheric Lens. Let’s say we have a lens where Max. Front Aperture = Max. Back Aperture = 20 mm and Min. Front Aperture = Min. Back Aperture = 10 mm. If we specify that we want the thickness to be Thickness = 15 mm, then setting the Thickness Aperture = 10 mm will give this result:
If we set the reference for the thickness to Thickness Aperture = 20 mm, we instead get this object:
Hopefully this helps to clarify the meaning of that parameter. Let me know if you have any more questions about the Annular Aspheric Lens.
Ethan
Ethan
  • December 9, 2022
Hi @ruik.Zhang,
Ethan
Thank you @Ethan. I will add this to our help files.
