Trying to sweep a standard surface, not working as expected
alexander_dumont
Hi all
I am using NSQ in Zemax, and trying to set up a swept standard surface, as seen on the attached figure:
Current setup
However, I am not getting the sweep I want. I actually do not get any sweep. As said in this post,
The explanation for using a swept surface is a little bit lacking in the Zemax manual. From this post, I've gathered that there is something wrong with my coordinates, but I’m not sure how to fix it. Any help on this would be of great help. I’ve been playing with numbers for a few hours with no success.
What I ultimately going for is a 360 degree sweep around the z-axis of the standard surface to create some semblance of a custom annular mirror that I can then optimize,
Alex
Best answer by Andrew_Davies
Try copying the example David worked out in this form post,
Andrew_Davies
Kevin Scales
Yes. That post has a good discussion and examples.
