Truncated Spherical Lens: How to model ?
Is it possible to truncate the top/bottom of a spherical lens in Zemax?
For example. I would like cut the top/bottom part of a spherical lens to produce a rectangular spherical lens as shown below.
Cheers!
Best answer by nadav.amitai
You can do it with User Defined Aperture (.UDA). See p. 433 in the help pdf file.
Your file should look something like that:
LIN -0.8 0.6
LIN 0.8 0.6
ARC 0 0 73.739 30
LIN 0.8 -0.6
LIN -0.8 -0.6
ARC 0 0 73.739  30
BRK
B.R
Nadav
LIN -0.8 0.6
LIN 0.8 0.6
ARC 0 0 73.739 30
LIN 0.8 -0.6
LIN -0.8 -0.6
ARC 0 0 73.739  30
BRK
B.R
Nadav
@Asuku:
Yes, a UDA should do the trick.  Additional detail can be found here:
  • July 15, 2024
@Asuku:
Very helpful. Thank you, Jeff.
  • July 17, 2024
Hi @Nadav & @Jeff.Wilde: A follow up question, will Zemax capable of producing ISO drawings of reshaped elements ?
Hi Asuku
I don’t know of a method. I am also interested in a solution.
