Tracing multiple ZRD ray files into one detector
  • Jun 28, 2023 7:40 PM UTC
  • 336 views
o.sonmez
Hi everyone,
I have multiple number of ray database files in non-sequential mode. The ZRD files are output of ray traces for different angles. With the multiple ZRD files, I want to see all these traced rays in my detector together. How can I achieve this?
Any comments or ideas are welcome.
Best answer by David
To be a bit more clear about this:
One way to do this is to not use a ray database. Instead, use the multiconfiguration editor to define each angle in its own configuration. Then you can select and trace each configuration in turn. For the first configuration, use “Clear & trace.” That will clear the detector and trace rays. Then select each configuration in turn and use “Trace.” That will add hits to the detectors without clearing them.
If you wish to use ray databases, then the only way I know is to save a dat file from each, and then define a Source File for each dat file and trace all those sources. To do this, you need some convenient object to store the rays on. Then you trace for the all Source File objects, and not the original sources. Rays will originate from the object locations where they were stored.
  • Jun 28, 2023 8:04 PM UTC
Create dat files. Then you could have a separate Source File for each and then just trace all the sources at once.
  • Jun 29, 2023 7:57 PM UTC
