Tolerancing with the RMS spot radius
  • Sep 25, 2023 3:28 PM UTC
  • 259 views
When tolerancing an optical system, i´ve set the criterion to be the RMS spot radius.
It is not clear however if this refers to the RMS spot radius for a field point along the optical axis, on the edge of the field of view or a weighted sum of the different field points. Can someone elucidate me?
Kind regards,
Best answer by Jeff.Wilde
@Jonasz :
There are three options for how fields are handled for tolerancing purposes:
Note that for user-defined fields, you can apply relative weighting factors:
  • Sep 25, 2023 4:39 PM UTC
@Jonasz :
