I have set up for the tolerance of a somewhat simple system using the temperature ranges in a multiconfiguration table. I am getting the error message that TRAD cannot be used in multiconfiguration tolerance analysis with no explanation or corrective actions. I want to include the lens manufacturers ROC tolerance in the analysis and I don’t recall running into this problem previously. Is there a workaround for this error?
Best answer by MichaelH
