Tolerancing CMOS with curved imaging surface.
Dear All,
I designed the compact imaging device for ophthalmology. The CMOS with curved imaging surface was used as a sensor because aberration curvature of field left unbalanced. ZEMAX-OpticStudio does not allow to introduce lateral displacements and tilts of a sensor using the operands TEDX and TETX. Please suggest how the parameters can be toleranced.
Sincerely,
Mark
Best answer by Mark.Nicholson
Put a coordinate break surface before the image surface and use TU** to put tolerances on its parameters
Thank you.
