The wavefront of the reference sphere
  • Sep 10, 2021 9:45 AM UTC
  • 6 replies
  • 1106 views
How to obtain the wavefront of the reference sphere through ray tracing, and what operand or function is used?This question makes me very anxious, I would be very grateful if someone answers:cry:
Hi Nancy
I had created this file. I did it a while ago so if there are any discrepancies let me know. The calculation can be done in the merit function.
Sandrine
On axis, the reference sphere is just a perfect sphere with radius equal to the exit pupil position, which you can get via EXPP. The ‘Wavefront’ of the system, is the real wavefront at the EXPP with the reference sphere subtracted.
Off axis this definition is much the same but there is some complexity due to the tilt aberration. OpticStudio uses the tilt-removed reference sphere, which gives the physically meaningful wavefront that controls image quality.
  • Mark
  • Sep 13, 2021 2:07 AM UTC
  • Mark
Hi Mark,
Thank you very much for your answers.
Then can I obtain the optical path data of the reference sphere on the exit pupil surface in any way, including on-axis and off-axis?
Sincerely
Nancy
Hi Nancy
Sandrine
  • Sep 16, 2021 12:55 PM UTC
Hi Sandrine Auriol
Thanks for your reply! The File really work for me!I love you so much!
Sincerely
Nancy
:joy: Thank you!
  • Sep 18, 2021 3:38 AM UTC
Hi Nancy
Sandrine
Hi Sandrine Auriol
Thanks again for your file! I found that I still have some questions about this file: Are there any practical uses for the optimized operands OPDM and OPDX, why and how to calculate them? Actually I cannot fully understand the explanation of these two operands in the help manual.
Best,Nancy
