The problem with API's IAS properties
  • Apr 27, 2021 1:53 AM UTC
  • 138 views
Hi
I want to use API setting FieldCurvatureAndDistortion.
But IAS properties is not FieldCurvatureAndDistortion properties.
Its like the image below.
What i can do?
thanks
Allie
  • Apr 28, 2021 5:11 PM UTC
Hi Sheng-BO,
What language are you using to connect to the API? It looks a bit like Excel. If it is a language that connects to the API using COM instead of .NET, then it could be that the intellisense is not reporting the full information. The Field Curvature/Distortion analysis has a full IAS interface as provided in the ZOS-API Syntax Guide here: ZOSAPI.Analysis.Settings.Aberrations.IAS_FieldCurvatureAndDistortion Interface Reference.
I inspected the Field Curvature settings interface in Matlab, and have confirmed that all settings are available, as shown below. Note: you can right-click the image and open it in a new tab for a higher res view.
You should be able to use any of these settings in your own code. For example, to change the value of Maximum Curvature, you would use a command similar to this: Curvature_setting.MaximumCurvature = 20.0.
Let us know if you have any trouble with this!
Allie
thank you
