Spot diagram for multi configuration
  • June 9, 2021
  • 5 replies
  • 482 views
To Who It May Concern:
Sometimes my spot diagram can't find where can show all configurations.  Why?
Zheng-Wu (L116837)
Best answer by Mark.Nicholson
Are you using the Configuration Spot Diagram? That works as expected for me:
If you use the Standard Spot Diagram, you need to set Config to All in the Settings:
Does this help or am I missing something?
- mark
  • June 10, 2021
I looked at your file. The configurations all have different spot diagrams, but the standard spot diagram when set to Color Rays by Config only displays the diagram for the current configuration. This seems wrong to me, but perhaps there is something I don't understand.
I think we need the advice of Zemax support.
- mark
  • June 10, 2021
That's it. My mistake. I did not set configurations to all.
Thanks!
Hi, Mark:
I like to put all configuration spot diagrams in one as your second spot diagram.  However, sometimes the 'Current' or 'All' don't show up next to 'Automatic'.
I don't know where my setting wrong is.
Zheng-Wu
Current and All will only show up when there is more than one configuration. - M
