Spherical concave mirror with rectangular aperture
  • 30 August 2022
  • 332 views
Hi, I have a simple question for you. I would like to implement a concave mirror (or lens) with rectangular aperture in NSC mode (like the one I attached in this post). The rectangle must have a shape 25 cm x 25 cm, while the spherical part must have a radius of 40 cm.
Which object type should I use? (I already tried Standard Surface, but I cannot get the rectangular shape).
Thank you in advance.
icon
Best answer by Flurin Herren 30 August 2022, 15:14
Badge +3
Hi Nicola,
Thanks for posting here in the forum!
In order to model a rectangular mirror in non-sequential, I would use the Off-Axis Mirror Object. With the Shape Parameter you can set it to rectangular (Shape 2) and with the X and Y Half Width you can set the dimensions.
If I take your sequential system on the image as a blue print, the non-sequential equivalent looks a bit like that:
Let me know if you have any other questions
Have a good day!
Thanks, it worked !!
