Sodium fluoride (NaF) in the catalog
  • May 11, 2022
  • 93 views
Nicola Nicassio
Hi, just a simple question. Is sodium fluoride (NaF) in the catalog or should be implemented as a nre material?
Thank you in advance
Best answer by Angel Morales
Hi Nicola,
Thanks for your post here! I’ve taken a look through some catalogs most likely to have that material defined (like MISC.AGF), but it doesn’t seem to be provided with our installs. You’ll need to define a new material for sodium fluoride -- you can follow the steps in this article to do so. In case it helps, you may be able to use this reference for pulling index data on this material: Refractive index of NaF (Sodium fluoride) - Li
Let us know if you have any more questions. Thanks!
Angel Morales
  • June 1, 2022
Hi Nicola,
