Seidel Image Simulation
  • Aug 13, 2020 3:32 AM UTC
  • 1368 views
John.Hygelund
As part of a demonstration, I want to simulate individual Seidel aberrations on image quality. I have a basic understanding of the connection between Seidel coefficients and wavefront aberrations. A Zernike surface seems like the way to do this, but I'm having trouble seeing the connection between Zernike polynomials and Seidel coefficients. In particular, interested in simulating W311, third order distortion. This webpage shows exactly what I'm trying to achieve https://www.opticsthewebsite.com/SeidelSimulation. Can OpticStudio do this?
Thank you, John
Best answer by Berta.Bernad
Hi John,
You can use the Zernike Standard Phase surface to introduce aberrations you want:
The Setup Tab > Editors Group (Setup Tab) > Lens Data Editor > Sequential Surfaces (lens data editor) > Zernike Standard Phase
You will find the description of the Zernike Standard Coefficients here:
The Analyze Tab (sequential ui mode) > Image Quality Group > Wavefront > Zernike Standard Coefficients
This table from Wikipedia (https://en.wikipedia.org/wiki/Zernike_polynomials) shows the relation between the equations and the corresponding aberration:
Here is another reference you may be interested in, as it relates the distortion with terms Z1 and Z2:
https://telescope-optics.net/zernike_coefficients.htm
However, both analysis (Zernike and Seidel) are calculated in a different way. Seidel coefficients are computed using paraxial ray trace data on a surface by surface basis, whereas Zernike coefficients are computed by tracing a grid of rays through the system which are integrated to get the wavefront at the exit pupil. This wave front is then fitted with the Zernike terms up to a specified order of terms.I’ve made a quick search on Google and it seems that there are some references if you want to convert from Zernike to Seidel, such as:
https://www.osapublishing.org/ol/abstract.cfm?uri=ol-7-6-262
Some Seidel aberrations (such as spherical, astigmatism or coma) can be modelled directly with the Irregular Surface, but distortion is a tough one as it can not be easily described with this kind of surface. Since distortion is just the variation of focal length vs. field, you can try to design a wide angle lens. You may have a look at the example \Zemax\Samples\Sequential\Objectives\Wide angle lens 100 degree field.zmx where distortion can be seen with Image Simulation tool in a similar way of your example.
Berta
Berta.Bernad
  • Aug 13, 2020 10:41 AM UTC
Hi John,
Berta
