Script a sequence of NSC ray trace and analysis
John.Hygelund
I would like to analyze stray light in non-sequential mode over a range of focus travel. Scripting this seems necessary given the duration for ray tracing and the large number of focus positions needed. I’m sure this is a common task and I’m reaching out for any possible example scripts. The basic functions would be
  1. Run ray trace
  2. Save detector output (inverse gray scale, incoherent irradiance, log -10 as image file)
  3. Update Z position of object
  4. Repeat steps 1-3
Everything except step 2 seems straight forward, so I’m mainly looking for help with saving detector data.
My preference would be to work directly in ZPL, but can work via the API (Matlab preferred) .
Thanks in advance for any help,
John
Best answer by John.Hygelund
@Oran , Thanks for your help. I’ve got the position updating and detector image saving in a loop, but I’m not finding how to initiate a new ray trace on each loop. The RAYTRACE keyword seems specific to sequential mode.
  • Visible
  • 22 replies
  • July 20, 2023
 Hello John,
For step 2 look at this thread:
And step 3 would look something like
POSITION_CODE = 3  # 3 is for Z
SETNSCPOSITION 1, OBJECT_NUMBER, POSITION_CODE, NEW_POSITION
Run it through your FOR loop and that’s it.
Oran
John.Hygelund
  • 71 replies
  • July 20, 2023
  • Visible
  • 22 replies
  • July 20, 2023
The raytracing keyword for NSC is NSTR
  • 108 replies
  • July 20, 2023
In ZPL, you can use NSTR to trace. Note that if your want to clear the detector (before the trace), you have to use a NSDD(1,0,0,0) first.
John.Hygelund
  • 71 replies
  • July 20, 2023
@Ray , Thank you. I’m up and running now.
