RMS Roughness on a lens - POP/Sequential Mode
  • June 3, 2021
  • 296 views
Dear Support,
I’m simulating, through POP/sequential mode, a system composed mainly by a DFB laser, as the source, and a microlens/mirror and evaluating its coupling to a standard SMF-28 fiber.
For my subsequent step, I need to take into account the surface roughness/imperfections of the microlens/mirror caused by the fabrication process.
The only parameter that I receive from my manufacturer is the rms of the surface, and I don’t know how I could properly implement it. I hope you could help me.
Thank you and looking forward to your answer.
Andrea
Hi Andrea
When tolerancing surfaces, we have an operand called TEZI that changes the surface into a Zernike Standard Surface. The TEZI operand specifies a RMS sag error. The coefficients of the Zernike are set so that they give the right RMS.
So I think you could use the same method in your case. If you want to have a look at how the software is doing it, you can run a tolerancing with TEZI and check a Monte Carlo file, or a sensitivity file by adding a SAVE operand in the tolerance data editor.
I have also copied a link that may help: How to use TEZI to tolerance for manufacturing-related surface sag error
Do not hesitate if you have any further questions.
Sandrine
Hi Andrea
Sandrine
