Resolution of objective lens design
  • Oct 29, 2021 9:02 AM UTC
  • 501 views
Dear all,
Please help me to find the resolution of objective lens design in unit lp/mrad?
Thanks
Girish
You will read this value in the MTF plot. The MTF is defined as:
For OpticStudio, modulationobject = 1
So
The MTF plot will give this value for a range of frequencies (cycles or lines per mm).
For more information about the MTF, have a look at Edmund Optics website: https://www.edmundoptics.co.uk/knowledge-center/application-notes/optics/introduction-to-modulation-transfer-function/
  • Oct 29, 2021 9:39 AM UTC
In the system explorer, “Units” section, you can switch the “MTF Units” from Cycles/millimeter to cycles/milliradian.
Cycles is the same as line pair.
  • Oct 30, 2021 4:11 AM UTC
Thankyou for your reply.
Actually, I am trying to simulate resolution of night vision objective with II Tube with 64lp/mm resolution with SNR 22.
Thanks
So
