Problem with using black box design files for Infinite conjugate microscope
  • November 18, 2022
  • 403 views
  • 39 replies
I am modeling an infinite conjugate microscope system using off-the-shelf designs from Thorlabs.
  1. Microscope objective: TL2X-SAP - 2X Super Apochromatic Microscope Objective, 0.1 NA
  2. Tube Lens 200mm: TTL200-A - Tube Lens, f = 200 mm, ARC: 350 - 700 nm
Individually the objective lens and tube lens designs works as expected. However, when they are put together, the image quality is far from nominal (1000 waves OPD).
I am unsure if it has got to do something with using multiple black box design files in a single zemax file or if there’s something fundamentally wrong with the combined design itself.
OPD
Image Sim
System
I have attached the zemax file with the combined microscope objective + tube lens and also the individual zemax BB files.
Any insight into what is causing the image quality to degrade by ≥ 1000 waves from nominal OPD is appreciated.
Thanks.
Best answer by Mike.Jones
Look at your Aperture/Afocal checkbox.  Is it checked or unchecked?  Try both ways.
Mike.Jones
  • 117 replies
  • November 18, 2022
Also, it looks like defocus. Try refocusing the inter-black box and the final back gocal length.
  • 39 replies
  • November 20, 2022
Thank you, you were correct. This was checked in the objective black box design file.
